Match-any or Match All For Class-map On Nexus?
Answered Question
Oct 16th, 2014
  I have an access-list MANAGEMENT
        permit udp any eq snmp any
        permit udp any any eq snmp
        permit tcp any any eq telnet
        permit tcp any eq telnet any
       permit tcp any any eq 22
       permit tcp any eq 22 any
My question does it matter if I use a match-any or match-all. I want to match anything in the access-list to classify the traffic correctly
 class-map type qos match-any MANAGEMENT
            match access-group name MANAGEMENT
Or
class-map type qos match-all MANAGEMENT
I understand a match-any is an or and a match-all is an and function. Does this apply to an access-list for  a class-map?
Correct Answer by Jody Lemoine about 2 years 10 months ago
It applies to match statements within the class map. In your case, you're only using one match statement, so there will be no difference between match-all and match-any, no matter how many entries are in the ACL. If your class map had two different ACLs in two different match statements , then the and/or logic of match-all and match-any would come into play.
Overall Rating: 5 (1 ratings)
Correct Answer
Jody Lemoine Thu, 10/16/2014 - 21:54
  • Gold, 750 points or more
  • Community Spotlight Award,
    Member's Choice, April 2016
