Warning message
VCS installation on UCS C240 using VMWare ESXi 5.5
Answered Question
Oct 17th, 2014
Hello to everybody
I have a trouble with installing Cisco UC products on UCS C240. I have VMWare ESXi 5.5. I'll write what I've done.
At first I made Virtual Disk (Raid), but I couldn't enter Netbios configuration for a long time. I pressed CTRL+H and after that I saw screen with shell>. It was my first time I worked with UCS C240 and I didn't saw same screens during UCS C220 configuration. After that I entered exit command and Netbios screen appeared. After that I installed VMWare ESXi, configured it and installed VCS ova template. Everythung worked correct.
BUT... After turning off and on the server VMWare ESXi didn't load, I looked to the console and saw the shell> screen. I think it isn't normal.
What I have to do to load my VMWare and don't see the shell> screen.
Thank you
Correct Answer by George Thomas about 2 years 10 months ago
Can you check your boot order? And make sure your HDD/RAID comes above the EFI shell?
Overall Rating: 5 (1 ratings)
Correct Answer
George Thomas Fri, 10/17/2014 - 10:19
  • Blue, 1500 points or more
