Warning message
IPsec VPN: multiple LANs on one side - is it possible?
Answered Question
Oct 17th, 2014
Hi folks!
I've an IPsec Site-to-Site VPN to a branch office (R2). There was one LAN (LAN1) at HQ and another (LAN2) at Branch office.
Tunnel termination points:
  • R1 - Microsoft ISA Server
  • R2 - Cisco 2921 ISR
LAN3 has been created recently, behind R2 (see the picture below):
current network configuration
So I need to gain an access to LAN3 from LAN1. How could I solve this problem? I see two options for now.
OPTION 1: Create a separate tunnel from R1 to R2
separate tunnel for each remote subnet
I see an issue here:
  1. How could I define a separate key for this tunnel?
    If I execute something like this:
    crypto isakmp key LAN1_to_LAN2_key address 1.1.1.1
    then LAN1 to LAN2 tunnel will be dropped because of the changed key
  2. Everything else seems good - policy maps, route-maps, etc.
    Traffic could be distinguished between them
OPTION 2: Create a summary route in VPN config
summary route
Issues:
  1. R1 does not seem to support such kind of configuration (source, section "Quick policy mode negotiation fails with a "No policy configured" error")
Running-config (security part) is attached
Correct Answer by Richard Burts about 2 years 10 months ago
From the Cisco side this is easy to solve. I can not address how to solve it from the R1 Microsoft side but suspect that it is not difficult.
You do NOT want a second tunnel to solve this. You want to change the access list that identifies traffic to be encrypted. If it were me I would add this line to your existing access list
 permit ip 192.168.3.0 0.0.0.255 192.168.101.0 0.0.0.255
or alternatively you could replace this line
 permit ip 192.168.2.0 0.0.0.255 192.168.101.0 0.0.0.255
with this line
 permit ip 192.168.2.0 0.0.1.255 192.168.101.0 0.0.0.255
Rick
Overall Rating: 4.5 (2 ratings)
michael o'nan Fri, 10/17/2014 - 07:50
  • Silver, 250 points or more
I don't believe this would be adding a tunnel you are just adding access to that subnet on your tunnel. Sorry I can't help with exact config but I know it can be done rather easily.
Correct Answer
Richard Burts Fri, 10/17/2014 - 09:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
with this line
Rick
Aliaksandr Trat... Mon, 10/20/2014 - 04:32
Thanks, Richard!
That worked. Actually from ISA Server I had to bring up another tunnel with the same parameters as the previous one (192.168.2.0/24) but for a new network (192.168.3.0/24).
Richard Burts Mon, 10/20/2014 - 09:28
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
It is interesting that from the ISA Server side you had to bring up another tunnel. I am glad that my suggestions helped you to solve it from the Cisco side. Thank you for using the rating system to mark this question as answered. This will help other readers in the forum to know that there is helpful information in this thread.
Rick
Aliaksandr Trat... Mon, 10/20/2014 - 22:58
Rick,
actually i've found a way to just add another address range to the existing tunnel (it seems that i was blind hadn't noticed it before). That also worked. So i decided to move to that right solution.
Although, I've discovered a new possibility to add another address range through creating another tunnel :)
Richard Burts Tue, 10/21/2014 - 07:01
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Thank you for posting back to the forum and updating us that you were able to just add another address range to the existing tunnel on the ISA Server. That makes sense and I agree that this is better than achieving the result by adding a new tunnel.
Rick
Related Content
