10-19-2014 06:12 AM
I've got a freepbx server hosted behind a Cisco rv016 multi wan router. Trying to get extensions outside the network to register on the SIP server using a paid dyndns.org host, registered and updating on the rv016.
RV016 is x.x.x.23
Freepbx is x.x.x.150
I've created port forwards on 5060, 5061, 10000, and 20000.
I've also set firewall permissions on those ports, originating on WAN, going to x.x.x.150 to be all allowed.
When I use an external port checking tool, despite the settings above, it still says port 5060/5061 are closed.
Any suggestions are appreciated.
10-19-2014 02:16 PM
SIP ALG uses port TCP 5060 and UDP 5060. Did you enable both?
10-20-2014 10:55 PM
Yes
Ports 5004 to 5084, and 10000 to 20000
TCP and UDP all forwarded to SIP address
Setup > Forwarding
[UDP] 5004 ~ 5084 forwarded to voip server
[TCP] 5004 ~ 5084 forwarded to voip server
[UDP] 10000 ~ 20000 forwarded to voip server
Setup > uPNP
UDP 5060
TCP 5060
Firewall > Access Rules
Allowed : 5004 ~ 5084 UDP
Allowed : 5004 ~ 5084 TCP
Allowed : 10000 ~ 20000 UDP
Port checking tools now say that port is open but 'filtered'
External extensions still not registering.
