Warning message
CISCO 881GW profile Inactive
Answered Question
Oct 20th, 2014
Hi all,
I'am trying to configure cellular interfacee on cisco 881GW but the profile is Inactive.
Bellow is my confuguration:
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = abcdef
Authentication = CHAP
Username: abcdef
Password: abcdef
chat-script gsm "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
interface Cellular0
 ip address negotiated
 encapsulation slip
 dialer in-band
 dialer idle-timeout 0
 dialer string gsm
 dialer-group 1
 async mode interactive
interface Dialer1
 ip virtual-reassembly in
 encapsulation ppp
 dialer pool 1
 dialer string gsm
 dialer persistent
 dialer-group 1
 ppp authentication chap callin
 ppp chap hostname abcdef
 ppp chap password 0 abcdef
 ppp ipcp dns request
line 3
 exec-timeout 0 0
 script startup gsm
 script dialer gsm
 script reset gsm
 login
 modem InOut
 no exec
 transport input all
 transport output all
ip route 0.0.0.0 0.0.0.0 Dialer1
Correct Answer by Carlos de Armas about 2 years 10 months ago
I think your problem might be here:
PDP Type = IPv4
Username: abcdef
Password: abcdef
interface Cellular0
 encapsulation slip
 dialer in-band
 dialer string gsm
 dialer-group 1
Make sure that the resalted information its correct, the profile config it´s wrong. Also check the chat-script, not all chat-scripts works for all carriers, the encapsulation too.
And i think that you should add a route for the cellular interface. Something like "ip route 0.0.0.0 0.0.0.0 Cellular 0 200" if you want to use it as backup.
Regards.
Overall Rating: 5 (1 ratings)
Correct Answer
Carlos de Armas Tue, 10/21/2014 - 04:26
PDP Type = IPv4
Username: abcdef
Password: abcdef
interface Cellular0
 encapsulation slip
 dialer in-band
 dialer string gsm
 dialer-group 1
Regards.
Anselme AMOUSSOU Tue, 10/21/2014 - 12:27
Hi Carlos,
You are right I changed the static route to 0.0.0.0 0.0.0.0 cellular0 and run a ping and the profile came UP. It means that the chat script and the profile is ok.
The issue now is that after the router reboot I need to run a ping from the router first before the profile get activated.
How can I bypass that process!!!
Anselme AMOUSSOU Mon, 12/01/2014 - 01:15
Hi Carlos,
Neither keep alive or ipsla help me.
Need your urgnet help ….
My Sim is activated for very short time,but most of the time its always INACTIVE.
Carlos de Armas Mon, 01/12/2015 - 03:17
Sry about the delay! the profile goes inactive due to lack of traffic. Try making a ping with source (use the vlan, interface that uses the cellular interface as output) and you will see that the profile goes active again.
Regards!
Carlos
