Is LACP with Normal Uplinks possible
Answered Question
Oct 21st, 2014
I need to setup a NIC team, using LACP on a Dell Server.
I have two switches, up-linked together (not stacked).
Is it possible to create a LACP group, two ports, one port from each switch?
Correct Answer by Jody Lemoine about 2 years 9 months ago
Unfortunately, no. There needs to be single device controlling all links for LACP to work correctly, so stacking is a minimum requirement for your switches to do this.
If you're looking for failover functionality in the event of a switch failure, there are other options depending on what you're running on that server. You can bridge the two links and rely on the switches' spanning-tree protocol to block one of them, for example.
Overall Rating: 5 (1 ratings)
Correct Answer
Jody Lemoine Wed, 10/22/2014 - 06:45
  • Gold, 750 points or more
  • Community Spotlight Award,
    Member's Choice, April 2016
