10-23-2014 01:23 AM - edited 03-07-2019 09:13 PM
hi
i have a pair of C3750X running IOS 15.2(1)E
they are connected over througt a WAN (Layer2 VPLS 802.1Q) connection.
the port on the Root Bridge is in a block state because there is a P2p Dispute. anyone got a clue to why this i happening
below is the port configuration, spanning tree configuration i have attached debug output from the Root Switch
Root Switch
spanning-tree mode mst
spanning-tree logging
spanning-tree mst 0 priority 4096
interface GigabitEthernet1/0/1
description ** xxxxxxx **
switchport trunk allowed vlan 276-281
switchport mode trunk
storm-control broadcast level 2.00
2nd switch
spanning-tree mst 0 priority 28672
description ** xxxxx **
10-23-2014 09:17 AM
The problem can be caused by STP or EtherChannel misconfiguration, or by an uni-directional link.
1- You can check the bi-directional functionality of the link or MST configuration?
2- if you configured "vlan dot1q tag native" , remove it.
Houtan
10-23-2014 10:49 AM
hi.
the link is is working when i filter off BPDU, and the vlan dot1q tag native is not enabled
10-23-2014 11:42 AM
Pruning VLAN 1 can be interupting for some STP functionalities. change following link on both of your interfaces:
switchport trunk allowed vlan 1,276-281
Houtan
