Warning message
Can't remove registered ephone in call-manager-fallback
Oct 23rd, 2014
This ephone and dn keeps registering so long as call-manager-fallback is not shutdown.
RTR001#show ephone registered
ephone-1[0] Mac:0FD4.9DA0.D415 TCP socket:[1] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 6/5 max_streams=1
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:7
IP:10.32.21.183 * 26602 SCCP Gateway (AN)  keepalive 4 max_line 2 available_line 1 dual-line
port 2/0/21
button 1: cw:1 ccw:(0)
  dn 2  number 4851  CM Fallback CH1   IDLE
Preferred Codec: g711ulaw
Lpcor Type: none
The MAC 0FD4.9DA0.D415 identifies port 21 on a Cisco VG224. After shutting down that voice-port, the ephone doesn't register when call-manager-fallback is enabled.
