Warning message
web authentication login page
Answered Question
Oct 23rd, 2014
i have configured my wlc for the web authentication, now work fine. But for the login page i must insert manual te virtual ip of the WLC (1.1.1.1).
There is a method that when you connect to the SSID the web page is displayed automatically?
Correct Answer by Rasika Nayanajith about 2 years 9 months ago
What code of WLC version are you using ? Also make sure opening web page is http & not https (normally most of sites, like google, automatically use https & those won't redirect)
Also check your DNS to make sure it properly resolve URL. Also try by adding a DNS entry for 1.1.1.1 IP as well.
Here are some reference WebAuth config example which may help you as well
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/69340-web-auth-config.html
Rasika
*** Pls rate all useful responses ***
Overall Rating: 5 (3 ratings)
Rasika Nayanajith Fri, 10/24/2014 - 02:51
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 Wireless
Webpage not displayed when you connected to it. (client state would be WEB_AUTH_REQD)
You have to open a web browser & then it should redirect to login page. If you have configured WebAuth then user has to enter the credentials. If you have configured Web passthrough then no username verification (you can include enter email ID as an option). Then only client will be in RUN state.
Refer this for different webauth configuration options
http://mrncciew.com/2013/03/21/wlc-web-authentication/
Rasika
dinocecchini Fri, 10/24/2014 - 23:00
Hi Rasika,
i configure the WebAuth but when i open the browser I'm not redirect to the login page, but if i enter the virtual ip the web page as shown.
Correct Answer
Rasika Nayanajith Sat, 10/25/2014 - 14:32
    2017 Wireless
Rasika
dinocecchini Tue, 10/28/2014 - 07:28
Hi Rasika, Sorry for the late replay, Thanks for the support, the problem was that i try to open a https page. There is a method for redirect however when i open a https page? Thanks again, Dino
Related Content
Trending Topics - Security & Network
