10-24-2014 10:19 AM - edited 03-17-2019 12:40 AM
I have a ATA 190 but can't I change the configuration.
The administration guide for SIP tells:
By default, the network configuration options are locked to prevent
users from making changes that could impact their network
connectivity. You must unlock the network configuration options
before you can configure them.
But how unlock this device?
11-16-2014 08:45 PM
Follow Admin Guide Chapter. B and password is cisco (24726) by default.
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cata/190/1_0/english/administration/guide/sip/ATA190_AG.pdf
Yasuhiro
11-16-2014 09:32 PM
Thanks but this doesn't help to unlock the web admin page
11-16-2014 10:05 PM
Does that mean ATA190's web admin page? If it does, this page's reply will help you, I think.
https://supportforums.cisco.com/discussion/12279506/ata-190-web-interface-id-password
11-16-2014 10:48 PM
Yes we are talking about the ATA190's web admin page.
But I am already logging in with the admin account and password. The settings are still unlocked.
The question is how to unlock all the settings once logged in as an admin?
02-18-2015 02:26 AM
03-28-2015 10:23 PM
Eduardo, did you manage to get this fixed? I am having the same problem. I have seen posts stating that most settings could be tweaked from IVR menu, but I don't see much information on IVR in Cisco's documentation. Appreciate all your response.
Rgds
FH
03-30-2015 03:18 AM
Hi fhamidkhan,
For disable second fxs line you can check this open bug, currently not fixed.
Cisco Bug: CSCut09504 - ATA-190 : Options to disable 2nd FXS Port
03-31-2015 11:33 PM
Thanks Eduardo, there are so many issues with the new Ata190, I hope Cisco is doing something about it. I couldn't register it to CME 10.5 for the reason mentioned in tac response and Cisco's dev team is working on it to get it fixed in the next release which should be out in a month or so. The problem I observed is when you create SIP profile for ATA On CME, it generates a file with SEP<ATAMAC>config.xml file where as ata request ATA<MAC>config.xml from tftp.
### File generated by Voice-Register Global SIP Profile ###
cme-cue-router-a#sh voice register tftp-bind
tftp-server url flash:/its/syncinfo.xml alias syncinfo.xml
tftp-server url flash:/its/SIPDefault.cnf alias SIPDefault.cnf
tftp-server url flash:/its/softkeyDefault_kpml.xml alias softkeyDefault_kpml.xml
tftp-server url flash:/its/softkeyDefault.xml alias softkeyDefault.xml
tftp-server url flash:/its/featurePolicyDefault.xml alias featurePolicyDefault.xml
tftp-server url flash:/its/SEP34DBFD1824BD.cnf.xml alias SEP34DBFD1824BD.cnf.xml
### Capture from debug tftp packets ###
Mar 30 11:12:42 CDT: TFTP: read request from host 10.252.149.82(51173) via GigabitEthernet0/0.1
Mar 30 11:12:42 CDT: TFTP: Looking for ATADBFD1824BD01.cnf.xml
Mar 30 11:12:42 CDT: TFTP: Sending error 1 No such file
### Cisco TAC response ###
Thanks for sharing the details, tried doing some research with the symptom and It looks like you’re hitting the following defect :
CSCus55079: ATA-190 does not create configuration file with prefix "ATA
Link: https://tools.cisco.com/bugsearch/bug/CSCus55079/
Rgds
FH
07-02-2015 12:53 AM
Mine works. I can register ATA 190 with CME10.5 on Router IOS 15.5
Here's a forum thread for your reference:
https://supportforums.cisco.com/discussion/12508931/ata-190-and-cme-105
Good luck,
ZHLEE
10-23-2020 02:28 PM
Did you ever get this to work? I have one here that I would like to use and I am also stuck
11-20-2014 07:07 PM
I found that bug report:
CSCur53864 / ATA190: Web GUI page options are greyed out
https://tools.cisco.com/bugsearch/bug/CSCur53864/?referring_site=bugqvinvisibleredir
I have to say I disagree with the Severity classification of that bug as "cosmetic". We should be provided with a way to configure these options.
12-06-2014 02:03 AM
10-23-2020 02:36 PM
Was anyone able to figure out a way to configure this to a sip provider? I have one here it appears all the specs in the device would match what I need to use as a VOIP ATA adapter for SIP but I am prevented from being able to change any of the config settings through the GUI logged in as admin. It would be a shame to add this to landfill over a mean technicality
