Warning message
Etherchannel
Answered Question
Oct 27th, 2014
hi
yesterday i try to make layer 2 ether channel when i provide encapsulation dot1 q in Cisco 2960 switch it not accept on the other side  Cisco 3560 accept this command.
Second when all configuration has been done the Cisco 2960 switch ether channel  one time  up and goes down state like this (d) and other side 3560 show suspended  like  (s)
plz can you send ether channel and trunk commands which i see where i do mistake
Correct Answer by Rahul Chhabra about 2 years 9 months ago
Hi Kabeer,
Please check out your configuration as I mentioned:
On both switches:
int range f0/0-1
switchport mode trunk
channel group 10 mo active (for Lacp)
no shut
exit
Some of the restrictions which should be match both sides:
1) Speed
2) Duplex
3) STP mode
4) Vlan membership (for access ports)
5) Native Vlan (for trunk link)
6) Allowed vlans (on trunks)
7) Trunking Encapsulation
Rahul Chhabra
Network Engineer
Spooster IT Services
Correct Answer by John Blakley about 2 years 9 months ago
Double post ... I answered you in the other thread
Overall Rating: 5 (2 ratings)
Martin Carr Mon, 10/27/2014 - 03:36
The reason is the 3560 supports both ISL and DOT1Q, hence you need to specify the same, 2960 does the latter only.
Post your EC configuration...
Martin
Correct Answer
John Blakley Mon, 10/27/2014 - 04:07
  • Purple, 4500 points or more
Correct Answer
Rahul Chhabra Mon, 11/10/2014 - 10:48
Hi Kabeer,
On both switches:
int range f0/0-1
no shut
exit
1) Speed
2) Duplex
3) STP mode
Rahul Chhabra
Network Engineer
