Warning message
Cisco UCS Server - 1Gbps Fibre (SX)
Oct 28th, 2014
Hi All,
Anyone can advise what kind of PCI-e Card I can use if I need a 1Gbps Fibre (SX) transceiver on the UCS C220 server?
Is the GLC-SX-MMD is compatible with any 10Gbps SFP+ card?
Eka
richbarb Tue, 10/28/2014 - 07:24
  • Cisco Employee,
Hello there,
The GLC-SX-MMD transceiver can be used with the ports that supports the 1Gbps speed.
The UCS C220 supports 1Gbps speed with RJ-45 ports only.
Richard
