Cisco Aironet AIR-LAP1142N-E-K9
I am using Cisco Aironet AIR-LAP1142N-E-K9 on my network and it's connected to Gigabitethernet port on my 3750 switch, but for some eason it's neotiating only 100Mbps all time even when I run speed auto from both sides. If I run 1000Mbps from the switch and the AP, I loose connectivity. Please find below details:
Device ID: BTaS-RYD-5F-AP02
Entry address(es):
  IP address: 192.168.15.252
Platform: cisco AIR-LAP1142N-E-K9   ,  Capabilities: Trans-Bridge IGMP
Interface: GigabitEthernet1/0/14,  Port ID (outgoing port): GigabitEthernet0
Holdtime : 138 sec
Version :
Cisco IOS Software, C1140 Software (C1140-K9W7-M), Version 12.4(21a)JA1, RELEASE SOFTWARE (fc1)
Output from the switch interface:
Port          Name                        Status          Vlan       Duplex     Speed    Type
Gi1/0/14  ***BTAS-7flr-AP03*   connected    trunk        full          a-100     10/100/1000BaseTX
Yasir
Leo Laohoo
Run a TDR on your switch.   I am suspecting you've got a faulty cable.
Do the following commands:
1.  Command:  test cable tdr interface Gi1/0/14;
2.  Wait for approximately 5 to 7 seconds to run the test;
3.  Command:  sh cable tdr interface Gi1/0/14; and
4.  Post the output to #3.
Please find below:
BTaS-7F-SW-2#test cable-diagnostics tdr interface gi
BTaS-7F-SW-2#test cable-diagnostics tdr interface gigabitEthernet 1/0/14
Link state may be affected during TDR test
TDR test started on interface Gi1/0/14
A TDR test can take a few seconds to run on an interface
Use 'show cable-diagnostics tdr' to read the TDR results.
BTaS-7F-SW-2#
BTaS-7F-SW-2#
BTaS-7F-SW-2#
BTaS-7F-SW-2#show cable-diagnostics tdr ?
  interface  Specify an interface for result
BTaS-7F-SW-2#show cable-diagnostics tdr int gi
BTaS-7F-SW-2#show cable-diagnostics tdr int gigabitEthernet 1/0/14
TDR test last run on: March 10 04:38:17
Interface Speed Local pair Pair length        Remote pair Pair status
Gi1/0/14  100M  Pair A     N/A                N/A         Not Completed
                Pair B     N/A                N/A         Not Completed
                Pair C     N/A                N/A         Not Completed
                Pair D     N/A                N/A         Not Completed
BTaS-7F-SW-2#
Uhhhhh ... what ancient IOS are you running????
