10-29-2014 04:20 PM - edited 03-18-2019 03:35 AM
I am going to TMS 13.2.2, installing Java 6 update 33 install TMSPE 1.0 and migrating the database. Then I am upgrading to TMS 14.2.2, running windows hotfix 980368, installing Java 7 update 17 and installing TMSPE 1.1. Then I am going to TMS 14.3. running zone running time zone update tool. Then upgrading to TMS 14.5.1 and TMSPE 1.3. I will run windows updates on final upgrade, not sure looking for suggestions. Does anyone have any thoughts on this process. I have not had to do these upgrades one after another. Usually time passes between. Customer wants to save the database phonebooks and jabber users are all manual.
Note from the Moderator: This post was originally posted as a blog. Reposted as a question so that it can get a faster response. Blogs are not used to post questions.
10-29-2014 04:43 PM
Which Operating System and SQL Server versions are you using? You might want to (or have to) upgrade these as well along the way. I recommend going for Win 2012 and SQL Server 2012.
-Kjetil
12-02-2014 07:18 AM
Thanks for you recommendation. We are opting to go with a new server and starting with TMSPE 1.3 and manually adding the 50 movi/Jabber users.
01-22-2015 08:23 AM
We are doing a fresh install using 14.6 and TMSPE 1.4. Thanks for your thoughts.
