Change ip default-gateway IP address
Answered Question
Oct 29th, 2014
  • Blue, 1500 points or more
hi all,
just a quick one, i'm going to change the IPs on our LAN switches.
will i get disconnected if i change the ip default-gateway IP?
i know i've configured a switch before without this and it still works.
i would be changing the SVI IP last.
no ip default-gateway 172.29.26.1
ip default-gateway 172.27.190.1
interface Vlan1
ip address 172.27.190.2 255.255.255.192
Correct Answer by Aref Alsouqi about 2 years 9 months ago
Hi Johnlloyd_13,
When remove/add the ip default-gateway you would stay connected, but when changing the ip address of the vlan (svi) on which you are connected you would be disconnected.
Aref
Overall Rating: 5 (1 ratings)
Correct Answer
Aref Alsouqi Wed, 10/29/2014 - 22:35
  • Bronze, 100 points or more
Hi Johnlloyd_13,
Aref
johnlloyd_13 Thu, 10/30/2014 - 21:48
thanks for the confirmation!
it's the feeling that you know the answer but had to re-confirm :)
Aref Alsouqi Fri, 10/31/2014 - 04:59
You are very welcome John.
Aref
