Warning message
CUCM Cluster "Partition Unalligned" Issue Resolution by PCD (Prime Collaboration Deployment)
Oct 30th, 2014
Dear all,
I will test soon (asap i got bootable 9.1.2 software) to solve "partition unalligned" issue with CUCM Cluster version 9.1.2.11900-12.
In my opinion, we can solve this issue with PCD as migrate unalligned cluster to a new cluster with same version.
Do anybody test it before?
What is your opinions?
Best Regards,
Mesut
Jaime Valencia Tue, 11/04/2014 - 06:52
  • Cisco Employee,
  • Hall of Fame,
    2011
Yes, PCD will do a fresh install of the VMs for the migration and then just move the CUCM data, this would be the equivalent of the last step of the Jump upgrade in which you restored the VMs into freshly installed VMs.
Related Content
