Warning message
nexus 5k
Oct 30th, 2014
Hi..
I have nexus 5k running software version : 5.0(3) N2(1). I need to configure IPSLA command on this switch but not sure whether this image support. I tried executing " ip sla 2 " command on this switch but it gave error. Pls help me and suggest whether this image support this command. If not, in which version would it work.
InayathUlla Sharieff Thu, 10/30/2014 - 04:32
  • Cisco Employee,
Anu,
N5K does not support IP SLA.
regards
Inayath
*Plz rate if this is helpfull.
Anukalp S Thu, 10/30/2014 - 04:46
Hi Inayath,
Thanks for your quick reply.. so IP SLA does not work on nexus 5k in any of images??
Could you pls share document stating same, i need to share this with my seniors.
InayathUlla Sharieff Thu, 10/30/2014 - 05:50
  • Cisco Employee,
Confirm  that currently N5K doesnt support IP SLA on any of the images.
I dont have any document handy.
Inayath
***Plz dont forget to rate all usefull psts.
Anukalp S Thu, 10/30/2014 - 06:28
Hi Inayat..
Thanks agian, actually i need to configure track via tracking ip sla. If ip sla does not in nexus 5k, could you suggest any other option.
Using IPSLA i was trying to monitor icmp for a ip.
pls help.
