Warning message
3750x add stack member
Answered Question
Oct 30th, 2014
  • Bronze, 100 points or more
I need to add another 3750x to an existing stack of 3 identical 3750x switches. My understanding is as long as the code matches and I connect the new stack member powered off and then power it on after all connections are made that should work without any problems on a production network. Please advise if there is more I can do to ensure a flawless procedure.
Thanks.
Correct Answer by Reza Sharifi about 2 years 9 months ago
I would have an outage window just in case something goes wrong:
Also, Have a look at table-5-1 in this link:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750x_3560x/so...
Also see:
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-3750-series-...
Overall Rating: 5 (1 ratings)
Related Content
