10-30-2014 05:26 PM - edited 07-05-2021 01:50 AM
I have a few Cisco 1141n that are stand alone AP's that have one SSID on them. I would like to assign the ssid to vlan 2 but also be able to keep the native vlan 1 as a trunk port on it for snmp graphing as well as management of the ap. My router is going to route the traffic and my switch is the dhcp server for both vlan's. How would I go about putting ssid J&B2 on vlan 2 but keeping the 10.10.1.0 network (vlan 1) as the ip address for management? I'm guessing it would be something along the lines of a sub interface but I am lost on do I create the sub interface on the gigabit port or the dot11radio0 interface or both?
I've attached a copy of my current config. Thank you for helping me figure this out.
Solved! Go to Solution.
10-30-2014 07:34 PM
I think I missed a line under int d0. Try this & see
encryption vlan 2 mode ciphers aes-ccm
Rasika
*** Pls rate all useful responses ****
10-30-2014 07:10 PM
Hi JK,
Following config will do it for you
dot11 ssid J&B2
vlan 2
authentication open
authentication key-management wpa version 2
guest-mode
wpa-psk ascii 7 14141D061C113E2E662F2627370054455B5817
interface Dot11Radio0
encryption mode ciphers aes-ccm
ssid J&B2
no shut
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
interface Dot11Radio0.2
encapsulation dot1Q 2
bridge-group 2
interface GigabitEthernet0.1
bridge-group 1
interface GigabitEthernet0.2
bridge-group 2
interface BVI1
ip address 10.10.1.252 255.255.255.0
ip default-gateway 10.10.1.253
******* SWITCH PORT ******
interface GigabitEthernetx/x
switchport trunk native vlan 1
switchport trunk allowed vlan 1-2
switchport mode trunk
Initial config used for this post will help you as well.
http://mrncciew.com/2013/11/14/autonomous-ap-with-external-radius/
Rasika
**** Pls rate all useful responses ***
10-30-2014 07:32 PM
Thank you for your response. I went ahead and changed my config to the following. I am now unable to connect to my wifi network. I was able to connect before it just put me on vlan 1. I changed the settings on my switch as well.
Did I do something wrong on the AP config?
Thank you for your help
10-30-2014 07:34 PM
Rasika
10-30-2014 07:40 PM
Good eye!
Thank you very much for your help. After seeing how you configured it this makes sense. Thank you again. Very appreciated!
10-30-2014 08:25 PM
No worries, Glad I was able to help you... :)
Rasika
