Warning message
Seb Rupik Fri, 10/31/2014 - 05:54
  • Silver, 250 points or more
Hi there,
IPv6 point to point links should always be /127, equivalent to IPv4 /31 .
Your two addresses will still use an entire /64, but will be masked as a /127 :
2001:2206:72fe::/64
       2001:2206:72fe::/127
       2001:2206:72fe::1/127
2001:2206:72fe:0001::/64
       2001:2206:72fe:0001::/127
       2001:2206:72fe:0001::1/127
..etc
cheers,
Seb.
Timothy Martin Thu, 11/06/2014 - 14:42
  • Cisco Employee,
There has been some guidance that says to reserve a /64 and configure the /127. That works well if you have “gobs” of space, like a /40 to work from.
The other school of thought is to configure all of your p2p links (/127) out of a single /64. Works for deployments that have a more limited amount of space, like a /48. Yes, that seems odd to say "limited"..
/128 with the same guidance. Do not use all 0’s or all 1’s in the host id
When allocating /127’s Make sure to start with xx:2 & xx:3
