11-01-2014 08:17 AM - edited 03-17-2019 12:46 AM
Hi Folks, Due to a technical oversight, we ordered 10.5 software via PUT for an upgrade from 6.1.5 using PCD however, we can't use 10.5 as it isn't supported by third party application but 10.0 is. Question is, as I have 10.5 media, could I upgrade to 10.5 using PCD then downgrade to 10.0 using the non bootable ISO from CCO?
Paul
11-01-2014 10:38 AM
No, you need 10.0 media for the upgrade
11-03-2014 04:19 AM
Thanks - thought as much.
