Prime Infrastructure - Custom SNMP Template
Nov 1st, 2014
Has anyone managed to get the Custom SNMP Template to work in PI 2.x? I can't get it to present any relevant data (yes, with generic ​dashlets).
I've tried to pull CISCO-ENTITY-SENSOR-MIB and other third-party MIBs with no luck.
I'm starting to suspect this is yet another not-so-ready-feature of PI....
Johan
Overall Rating: 5 (1 ratings)
Brian McPhillips Fri, 11/07/2014 - 07:04
Hi Johan,
I am having some trouble with Custom SNMP also. I have imported the mibs and deployed the template but i'm not getting any information back. Is the information supposed to display in Device Work Center?
AFROJ AHMAD Sat, 11/08/2014 - 07:11
  • Cisco Employee,
Hi All,
This feature does work..
hope you are following the correct steps:
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-0/u...
For your reference  ,check the verify you are doing all the steps:
Step1:
Design > Custom SNMP Templates  > Create the Template
step 2: Design > Monitor configuration
select the template
Name it and other settings...
Step 3::Deploy >Monitoring Deployment
Select the template > click Deploy
select the devices or group of devices.....
Step 4:
Home >Detail dashboard > Devices
click > Add dashlet  > device dashlet >> click Gereric Dashlet (configure the generic dashlet by selecting the right template)
Hope it will help
Thanks-
Afroz
****Ratings Encourages Contributors *****
Brian McPhillips Mon, 11/10/2014 - 03:27
Thanks Afroz,
Do you know if there is an option for alerting on 3rd party polling?
AFROJ AHMAD Mon, 11/10/2014 - 05:25
  • Cisco Employee,
Can you explain more or little specific about what you want to achieve with 3rd party devices.
Brian McPhillips Mon, 11/10/2014 - 05:39
Simply if the 3rd party device goes down and polling fails an alert would be generated similar to a cisco router/switch to notify of an outage.
AFROJ AHMAD Mon, 11/10/2014 - 07:02
  • Cisco Employee,
I am not sure about the alert but if  the devices is in managed state . you can do the SNMP polling after adding the respective MIB ,if required.
Thanks-
Afroz
