Warning message
Help with understanding download speeds using large and small files
Nov 2nd, 2014
Hi There,
I am doing some throughput testing between two VMs on the same subnet which happen to also be on the same ESXi Host and share the same Nexus 1000v. Both VMs are using the latest VMXNET3 drivers and the network card properties shows the NIC speed as being 10Gbps.
VM1 <--- N1KV --> VM2
VM1 = FTP Server
VM2 = FTP Client
Test #1:
When running a FTP test and pulling down a 1.5GB file, VM2's network graph is showing that it can download roughly about 250-300,000Kbytes/sec (or 1.5-2.0Gbits/sec). Not too bad !
Test #2:
I then created 1,500 x 1MB small files and ran the same FTP test again. This time to download all 1,500 x 1MB files, VM2's network graph is only peaking at about 30-40,000KBytes/sec (or 200-300Kbits/sec). Urghhh....
I'm just wondering why the large difference in throughput between FTP-ing a large 1.5GB file as opposed to FTP-ing 1,500x1MB files. Is this the expected behaviour? Should we be getting better throughtput with Test #2  - if so, what do we need to do to improve this?
Thanks.
Andy
rais Sun, 11/02/2014 - 14:52
  • Silver, 250 points or more
FTPing a large file will give enough time for the TCP window size to get utilized to its peak.
Small 1 Meg files are too small for tcp to use its window size to a full potential. Moreover, FTP is not going to transfer all these files simultaneously. It has to do it one by one.
IPERF can also be used to check the available bandwidth.
