Fail to Chage the Interdigit Timeout Value in Cisco Gateway
Nov 3rd, 2014
Hello Everybody
I have this call flow:
PSTN (FXO) --> TCL File | Gw (H323) --> CUCM --> IP Phone
I have next Dial-peer in Gateway whith 9T pattern:
dial-peer voice 101 voip
 translation-profile outgoing test
 destination-pattern .T
 session target ipv4:10.1.1.12
 dtmf-relay h245-alphanumeric
 no vad
Please your help to reduce the interdigit timeout value because 10 seconds are too long.
I have tried this:
In the voice port:
voice-port 0/1/0
 timeouts interdigit 2
Under Telephony Service:
telephony-service
Under H323:
h323
  h225 timeout t302 2
No option worked. Some suggestion??
Thanks in advance!
ogencheva Mon, 10/26/2015 - 07:12
Hello there. I just ran into the same issue on 3945E running 154-3.M4 code. I have opened a Cisco case, but not getting anywhere with it yet.
Carlo Poggiarelli Mon, 10/26/2015 - 09:08
  • Green, 3000 points or more
Hi.
Are you also using a TCL script?
please post your config and your call flow
Carlo
ogencheva Tue, 10/27/2015 - 08:22
Thank you for your note. I got my issue resolved. There were not a TCL script involved. I was testing a SRST setup and was trying to change interdigit timeout with  timeouts interdigit command under voice-port with no affect. The actual command that changes it for eFXS ports (phones registered to SRST gateway) is timeouts interdigit  command under call-manager-fallback.
