ZBF woes
Darren Hunter
Hi I’m having some difficulty in understanding the behaviour of zone based firewalls on a 887va router, I do not understand the implications of including the self zone in a zone-pair. It seems that if you include the self zone in a pair with any other zone, the self zone becomes restrictive between all zones whether paired or not. For example if I include the self zone in a pair with the OUTSIDE zone, pinging the router from a host from the INSIDE zone no longer works…..
Secondly we operate a DMVPN  (this is a spoke router) and the tunnel will successfully establish with the following traffic configured to PASS
Tcp 4500
Tcp 500
ESP
GRE
However traffic through the tunnel will fail (including rip).
If however I modify the firewall policy to permit all traffic to and from the Self and OUTSIDE zones, tunnel traffic seems to work successfully between the SELF and VPN zones and the VPN and internal zones.
However given that all traffic destined for the tunnel would be encapsulated in a GRE header and GRE is permitted between the SELF and OUTSIDE Zones, I cannot see what other ports would need opening?
I’ve included some config below, any help would be greatly appreciated.
Access Lists
Extended IP access list OUTSIDE>INSIDE
    10 permit ip any any
Extended IP access list OUTSIDE>SELF
(   if this entry is included tunnel traffic works   permit ip object-group DMVPNIPGROUP object-group SELF (818 matches))
    10 permit gre object-group DMVPNIPGROUP object-group SELF
    20 permit tcp object-group DMVPNIPGROUP object-group SELF eq 4500
    30 permit tcp host HO host SELF eq 22 (18589 matches)
    40 permit tcp object-group DMVPNIPGROUP object-group SELF eq 500
    50 permit esp object-group DMVPNIPGROUP object-group SELF (424 matches)
    70 deny ip any any (7570 matches)
Extended IP access list SELF>OUTSIDE
(   if this entry is included tunnel traffic works       8 permit ip object-group SELF object-group DMVPNIPGROUP (1013 matches))
    10 permit gre object-group SELF any
    20 permit tcp object-group SELF any eq 4500
    30 permit tcp object-group SELF eq 22 host HO (12899 matches)
    40 permit tcp object-group SELF any eq 500
    50 permit esp object-group SELF any
Extended IP access list SELF>OUTSIDE_Insp
    10 permit tcp any any eq domain
    20 permit udp any any eq domain (86 matches)
Extended IP access list SELF>VPN
    10 permit ip any any (31 matches)
Extended IP access list SSH_Allow
    20 permit tcp network_obj HO any eq 22 log (22 matches)
    70 permit tcp LocalSubnet any eq 22
    80 deny ip any any log (8 matches)
Extended IP access list VPN>INSIDE
    10 permit ip any any (568 matches)
Extended IP access list VPN>SELF
    10 permit ip any any (15 matches)
Zone: self
  Description: System defined zone
Zone: OUTSIDE
  Member Interfaces:
    Dialer1
Zone: INSIDE
  Member Interfaces:
    Vlan1
Zone: VPN
  Member Interfaces:
    Tunnel0
Zone-pair              : OUTSIDE>SELF
Source Zone            : OUTSIDE
Destination Zone       : self
Service-policy inspect : PM-OUTSIDE>SELF
  Class-map : CM-OUTSIDE>SELF(match-any)
  Action : pass log
  Class-map : class-default(match-any)
  Action : drop log
Zone-pair              : INSIDE>OUTSIDE
Source Zone            : INSIDE
Destination Zone       : OUTSIDE
Service-policy inspect : PM-INSIDE>OUTSIDE
  Class-map : CM-INSIDE>OUTSIDE(match-any)
  Action : inspect
   Service Policy: http PM-DPI_HTTP_OUT
  Class-map : CM-INSIDE>OUTSIDE2(match-any)
  Action : inspect
  Action : drop log
Zone-pair              : SELF>OUTSIDE
Source Zone            : self
Service-policy inspect : PM-SELF>OUTSIDE
  Class-map : CM-SELF>OUTSIDE(match-any)
  Action : pass log
  Class-map : CM-SELF>OUTSIDE_Insp(match-any)
  Action : inspect
  Action : drop log
Zone-pair              : VPN>INSIDE
Source Zone            : VPN
Destination Zone       : INSIDE
Service-policy inspect : PM-VPN>INSIDE
  Class-map : CM-VPN>INSIDE(match-any)
  Action : pass log
  Action : drop log
Zone-pair              : INSIDE>VPN
Destination Zone       : VPN
Service-policy inspect : PM-INSIDE>VPN
  Class-map : CM-INSIDE>VPN(match-any)
  Action : pass log
  Action : drop log
Zone-pair              : SELF>VPN
Source Zone            : self
Service-policy inspect : PM-SELF>VPN
  Class-map : CM-SELF>VPN(match-any)
  Action : pass log
  Action : drop log
Zone-pair              : VPN>SELF
Source Zone            : VPN
Service-policy inspect : PM-VPN>SELF
  Class-map : CM-VPN>SELF(match-any)
  Action : pass log
  Action : drop log
 Class Map type inspect match-any CM-SELF>OUTSIDE_Insp (id 33)
   Match access-group name SELF>OUTSIDE_Insp
 Class Map type inspect match-any CM-VPN>INSIDE (id 29)
   Match access-group name VPN>INSIDE
 Class Map type inspect match-any CM-INSIDE>VPN (id 30)
   Match access-group name INSIDE>VPN
 Class Map type inspect match-any CM-SELF>VPN (id 47)
   Match access-group name SELF>VPN
 Class Map type inspect match-any CM-VPN>SELF (id 48)
   Match access-group name VPN>SELF
 Class Map type inspect match-any CM-OUTSIDE>SELF (id 4)
   Match access-group name OUTSIDE>SELF
 Class Map type inspect match-any CM-OUTSIDE>INSIDE (id 5)
   Match access-group name OUTSIDE>INSIDE
 Class Map type inspect match-any CM-INSIDE>OUTSIDE (id 6)
   Match protocol http
 Class Map type inspect match-any CM-SELF>OUTSIDE (id 7)
 Class Map type inspect match-any CM-INSIDE>OUTSIDE2 (id 10)
   Match protocol https
   Match protocol smtp
Sounds like you are having some problems :)
It would be easier to see what has been done if you posted your running-config, instead of show commands, they are harder to follow than the running-config.
And its UDP port 500 and 4500 you want to open, not TCP.
Cannot believe I didn't see that, i'm gonna test a little more but I think that's it.
thanks for your help
