Warning message
Cisco QM 8.5.2.200 change hostname and ip address of server?
Nov 5th, 2014
  • Bronze, 100 points or more
Customer wants to change the server ip and hostname of the Quality Management 8.5.2.200 box.
Can this be done?  I can’t find a document on steps.
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/workforce_optimization/qm_8x/installation/guide/qm852-installation-guide-cisco.pdf
Clifford McGlamry Fri, 11/07/2014 - 21:25
  • Silver, 250 points or more
  • Community Spotlight Award,
    Best Publication, November 2015
Yes, you can.  Go to the server, and locate the PostInstall.exe file.  Run that, and it will allow you to change the values in the configuration on the server.  Do this after you change it on the OS.
Cliff
Please rate helpful posts.
