Warning message
Unable to establish flexvpn spoke to hub via nat
topology:
c2901[public IP]----(internet)-----[some nat device]---c881
IOS 15.4(3)M on both ends.
c2901: hub
c881: spoke
I think I tested all the possible examples i found.
on hub:
  ikev2 stuck in IN-NEG: Status Description: Responder waiting for AUTH message
On spoke:
 ikev2 stuck in IN-NEG:Status Description: Initiator waiting for INIT response
c2901 config:
aaa new-model
aaa authorization network default local
crypto ipsec transform-set test esp-aes 256 esp-md5-hmac
 mode transport
crypto ikev2 authorization policy test
crypto ikev2 profile test
 match address local [public_IP_of_c2901]
 match identity remote fqdn spoke.test
 identity local fqdn hub.test
 authentication remote rsa-sig
 authentication local rsa-sig
 pki trustpoint hub.test
 nat keepalive 20
 aaa authorization group cert list default test
 virtual-template 2
crypto ipsec profile test
 set transform-set test
 set ikev2-profile test
interface Virtual-Template2 type tunnel
 ip address 10.128.99.1 255.255.255.252
 ip mtu 1400
 ip nhrp network-id 999
 ip nhrp redirect
 tunnel source GigabitEthernet0/0
 tunnel protection ipsec profile test shared
c880 config:
aaa new-model
 mode transport
 match address local interface FastEthernet4
 match identity remote fqdn hub.test
 identity local fqdn spoke.test
 pki trustpoint test
 nat keepalive 20
interface Tunnel999
 ip address 10.128.99.2 255.255.255.252
 ip mtu 1400
 ip nhrp redirect
 tunnel source FastEthernet4
 tunnel destination [public_IP_of_c2901]
 ip address dhcp
I have no problem to establish ipsec tunnel when both ends have static public IP with the same pki used on both ends. The only difference is that both sides I do not have any virtual templates just tunnel interfaces.
What I am trying to achieve is a working p2p tunnel from a spoke on dhcp behind nat  to hub on public IP. I think I spent the last 2 months trying to get it working. Please help.
Graham Bartlett Sun, 11/30/2014 - 12:43
  • Cisco Employee,
The reply from the Hub isn't coming back to the spoke - check the NAT device to see why this is being dropped.
cheers
