11-11-2014 08:39 AM - edited 03-15-2019 06:03 AM
For some agents in UCCX 10.5, when they log into Finesse, on the home page, they see this error (it's under the Voice CSQ report I believe):
"Error processing report. Refresh page or contact administrator"
It doesn't happen for every agent. We are using resource groups, not skills. I have checked to make sure the agent is in the correct CSQ, Resource Group and Team.
Has anyone encountered this error before?
11-11-2014 01:16 PM
Aaron,
Did you ever get this corrected?
I'm having the same issue.
Dan
11-11-2014 02:04 PM
Dan - no I have not. I posted this morning hoping someone would have an answer. It's good to know I'm not the only one with the error!
11-11-2014 09:34 PM
Please attached the CUCI start up.log and finesse catalina logs.
Also Can you verify below:
11-12-2014 07:54 AM
Reena - yes there are entries under collection name/collection type. I'll have to dig around for the log files above.
11-16-2014 05:44 PM
The solution to this problem - the team did not have the correct CSQ assigned! :(
11-04-2016 05:04 AM
Thank you for posting the solution. This fixed my issue :)
06-14-2018 02:18 AM
Thank you !
10-24-2016 07:07 AM
I was having the same issue with only 1 agent, the rest of the agent in the same team was working fine, after investigation the issue was i have created a value list and forget to add this agent to this value .. now its working fine :)
Thanks for you notes :)
