Warning message
Upgrade Order 9.x to 10.5
Answered Question
Nov 11th, 2014
We're currently running the below UC applications and I'm trying to determine the best order for migration:
CUCM 9.1.2
CUC 9.1.2
CUAC Enterprise 9.1.1
Does the Attendant Console have to be migrated first? Is anyone running the CUAC 9.x in a 10.x environment? If possible we would like to hold off on upgrading that component until later, but not sure if it's possible.
Correct Answer by Jaime Valencia about 2 years 9 months ago
CUC is pretty much a wildcard, you can upgrade it at anytime and still keep CUCM compatibility.
Yes, no AC on 9.x is compatible with 10.x CUCM, but 10.X ACs are compatible with 9.x CUCM.
It would be AC -> CUCM -> CUC
Overall Rating: 5 (2 ratings)
Correct Answer
Jaime Valencia Tue, 11/11/2014 - 10:08
  • Cisco Employee,
  • Hall of Fame,
    2011
Jeff Venier Tue, 11/11/2014 - 10:51
Thank you Jaime, that's what I figured, but was hoping I could do it last. Also, just to confirm, the CUCM and CUC can be done in either order, correct?
Correct Answer
Jaime Valencia Tue, 11/11/2014 - 10:52
  • Cisco Employee,
  • Hall of Fame,
    2011
