11-12-2014 01:43 AM - edited 03-17-2019 12:53 AM
I have cisco phone 9951 .
when I try to call to extension
the video not working.
version phone's sip9951.9-4-1-9
System version: 9.1.2.10000-28
any idea ?
11-12-2014 03:08 AM
if you are getting a black screen on the phone then you may be running into the following issue, as described in the release notes for this firmware
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/9971_9951_8961/firmware/9_4_1/english/release_notes/P567_BK_84CD4C2B_00_8961_9951_71-release-notes-9_4_1.pdf
"Cisco Unified IP Phones 9951 and 9971 One-Way Video Calls:
Because of limitations in the H.264 video signaling standards, Cisco Unified IP Phones 9951 and 9971 may not correctly display video that is received from devices supporting resolutions greater than 640 x 480. In this case, the user sees a black video screen. To ensure that video from such devices displays properly on the IP phone, configure high definition phones and Cisco Unified IP Phones 8961, 9951, and 9971 into different call regions and limit the video bandwidth to 384 kb/s when calling between regions."
Manish
11-13-2014 05:14 AM
could you please share your configuration of ip phone?
Thanks.
05-27-2016 11:01 AM
I am facing the same problem, with the same scenario. Can you tell me if you got any solution?
05-28-2016 08:47 AM
You can try unchecking Media Termination Point Required on the phone and then check. Also please make sure there is no bandwidth restriction there for the video calls.
Deepak
