Warning message
ASA 5550 SPF Error....
Answered Question
Nov 12th, 2014
Hi all,
My knowledge is pretty limited on the subject, and as a Sys Admin I'm by no means an expert in Cisco Firewalls. But, through a little self teaching and plenty of Google searches I've managed to set up an ASA 5550 on our network, and it's been running fine.
Now though, our circumstances have changed and I need to be able to take advantage of the AFP modules on the ASA 5550. I understand that I can only use ethernet or fiber on each port, not both. That's fine.
But when I try to change any of the GigabitEthernet ports to SFP via "Configure Hardware Properties" , I get the following error:
[OK] Interface GigabitEthernet1/3
[ERROR] speed 1000 negotiate
ERROR: % Invalid input detected at '^' marker.
This happens whether I change the option to either negotiate or non negotiate, and the only Duplex option if Auto.
This happens whether there is fiber attached or not, and I know the fiber cards/cables involved are all working fine.
Any help would be greatly appreciated.
Correct Answer by Vibhor Amrodia about 2 years 9 months ago
Which version of ASDM are you running ?
Would you be able to try it from the CLI and see if that works ?
Thanks and Regards,
Vibhor Amrodia
Overall Rating: 5 (1 ratings)
Correct Answer
Vibhor Amrodia Thu, 11/13/2014 - 03:11
  • Cisco Employee,
Thanks and Regards,
Vibhor Amrodia
Related Content
