Warning message
How to remove @domain from VCS H.323 call payload ?
Nov 13th, 2014
I have a VCS-C and VCS-E setup and wish to call an external Polycom VBP that is not using @domain in
its gatekeeper registrations.
Is there any way to alter/transform only the call payload to E.164 only, but yet retain the full [email protected]
for call routing ?
I believe Polycom VBPs call it ' Send parsed ANNEX O string Outbound '.
I have a large number of sites that work this way and I am trying to avoid asking all of them to manipulate their incoming
strings.
Thoughts ? :)
Jens Didriksen Fri, 11/14/2014 - 13:29
  • Blue, 1500 points or more
This from their release notes; "In certain solutions with older
VBP VOS it may be desired to revert the outbound ANNEX O [email protected] string to be modified and sent as the user portion only. This option is only needed when dialing ANNEX O destinations to VBP VOS 7.2.2 from VBP VOS 11.2.x systems."
So doesn't look like it applies to your deployment? What happens if you use [email protected]_address instead of domain?
Another option would be to neighbour your VCS-E with the VBP, use a prefix to send all calls to that destination directly to that neighbour zone; i.e. if the address is [email protected], and you add a prefix, say, #01, you would dial #0112345, then strip #01 so it'll only use 12345 for the call proper..
/jens
Please rate replies and mark question(s) as "answered" if applicable.
rouellette Fri, 11/14/2014 - 13:41
Thanks for the reply !
A Polycom solution is feasible, but I would prefer to fix the issue at the single source (Cisco VCS-E)
The Polycom sites I speak of, are often technically weak and independent, so making changes to each site (over 100) is a lot of work and coordination, not to mention the disruption of service.
Nonetheless, I thank you for your input :)
Jens Didriksen Fri, 11/14/2014 - 14:08
"A Polycom solution is feasible, but I would prefer to fix the issue at the single source (Cisco VCS-E)"
Neighbouring will do that, but it looks like you'll have to create a lot of neighbour zones, which might not, in your case, be practical either.
/jens
