11-13-2014 06:21 PM - edited 07-05-2021 01:56 AM
I´m looking for the CLI command to asign the primary controller name and IP from the master controller. So as AP's join the master controller, I can move them to their new Controller. I would like to do this thru the CLI of the master controller when I rename the AP's with a script that I write after inventorying them. Thanks to all who have any knowledge on this CLI command.
Solved! Go to Solution.
11-13-2014 07:18 PM
Command: config ap primary <WLC name> <AP Name> <WLC Management IP address>
11-14-2014 01:55 PM
Hi Mark,
Can you please mark this post as "Answered" if the recommendation has fixed the issue?
11-13-2014 07:18 PM
11-14-2014 05:40 AM
Leo Laohoo
Thanks so mush it's a lot easier to assign controller to a large group of new AP's this way.
I used this command from the master controller to change them to the NEW controller.
and it works GREAT...
(Cisco Controller) >config ap primary-base <WLC name> <AP Name> <WLC Management IP address>
11-14-2014 01:55 PM
Hi Mark,
