11-19-2014 04:58 AM
I know that you implemented some shortcuts in 5.1.3 for bundle-ether and TenGigabitEthernet. Any plans to implement the same function for pw-ether? Really annoying to work with pw-ether at the moment, when it gets displayed as PExxxxx in some views but you must use pw-ether xxxxx to show/configure the interface
RP/0/RSP0/CPU0:9k#show interfaces description | in PE Wed Nov 19 13:47:47.177 CET PE10001 up up test-xxxxx RP/0/RSP0/CPU0:9k#show interfaces PE10001 ^ % Invalid input detected at '^' marker. RP/0/RSP0/CPU0:9k#show interfaces pw-ether10001 Wed Nov 19 13:49:35.505 CET PW-Ether10001 is up, line protocol is up Interface state transitions: 11 Hardware is PWHE Ethernet Interface, address is a80c.0d71.4215 Description: test-xxxxx Internet address is 1.1.1.1/31 MTU 1514 bytes, BW 10000 Kbit (Max: 10000 Kbit) reliability 255/255, txload 0/255, rxload 0/255 Encapsulation ARPA, loopback not set, ARP type ARPA, ARP timeout 04:00:00 L2Overhead: 0 Generic-Interface-List: pw-he Last input 00:00:00, output 00:00:00 Last clearing of "show interface" counters never 30 second input rate 1000 bits/sec, 4 packets/sec 30 second output rate 1000 bits/sec, 4 packets/sec 3830527 packets input, 989740649 bytes, 4521 total input drops 0 drops for unrecognized upper-level protocol Received 0 broadcast packets, 4501 multicast packets 3861314 packets output, 921387947 bytes, 0 total output drops Output 0 broadcast packets, 78706 multicast packets RP/0/RSP0/CPU0:9k(config)#interface pe10001 ^ % Invalid input detected at '^' marker. RP/0/RSP0/CPU0:9k(config)#interface pw-ether 10001 RP/0/RSP0/CPU0:9k(config-if)#
/Regards Peter
11-26-2014 10:46 PM
"bump"
12-01-2014 11:15 AM
Peter, we're working on it. Stay tuned.
06-02-2015 10:38 PM
Any update on this? Running 5.2.4 now and still no pwhe shortnames.
06-03-2015 05:09 AM
hi peter,
this is tracked with ddts: CSCur91179 need shortcut name for pseudowire ether to PE for show CLIs
I see it is not integrated yet, let me get that going right away. apologies for the delay here!
cheers!
xander
