ā11-20-2014 04:00 AM - edited ā03-13-2019 08:44 PM
Is it possible to deploy two VG224 with H323 gateway which connect to the CUCM in the head office.
Call flow
When a user dial local number or international number from the analogue and cisco phone the call should be routed to the PSTN line via the H323 gateway, but when they try to ring other site in the company the call should be routed to the CUCM (four digit dialing). All incoming call form outside the company should come via the PSTN.
See Diagram Below
ā11-20-2014 06:56 AM
Yes, that is possible.
ā11-20-2014 08:48 PM
Hi Jamie,
Does the configuration below look okay in what we want to achieve?
Call Flow : PSTN >> 2961 Gateway >> VG224 (H323)
Configuration on the 2961 Gateway (H323)
voice service pots
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip refer h323
modem passthrough nse codec g711alaw
sip registrar server expires max 3600 min 3600
voice class h323 1
h225 timeout tcp establish 3
interface GigabitEthernet0/1
ip address 192.168.10.1 255.255.255.0 //IP ADDRESS OF ROUTER GATEWAY
no ip mroute-cache
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.10.1 //IP ADDRESS OF ROUTER GATEWAY
dial-peer voice 10 voip
description incoming calls from VG //accept all incoming calls from VG
voice translation-rule 1
rule 1 /^/ /00/ type any unknown plan any unknown
rule 2 reject //
voice translation-rule 2
rule 1 /^7920\(72..\)/ /\1/ type any unknown plan any unknown
rule 2 /^7920\(73..\)/ /\1/ type any unknown plan any unknown
rule 3 reject //
voice translation-rule 3
rule 1 /^72..$/ /077920\0/
rule 1 /^73..$/ /077920\0/
voice translation-rule 4
rule 1 /^0/ // type any unknown plan any unknown
rule 2 reject //
rule 3 /^7.../ /0779207200/
voice translation-rule 5
rule 1 /^7.../ /0779207200/
voice translation-profile FromPSTN
translate calling 1
translate called 2
voice translation-profile ToPSTN
translate calling 3
translate called 4
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711alaw
no vad
Dial-peer voice 100 voip
Description outgoing calls to the VG
Destination-pattern 3000
voice-class h323 1
session target ipv4:192.168.10.10 //IP ADDRESS OF VG224
codec g711alaw
fax rate disable
fax protocol none
no vad
Configuration on the VG224
voice service voip
no ip address trusted authenticate
h323
voice class h323 1
interface FastEthernet0/0
ip address 192.168.10.10 255.255.255.0 //IP ADDRESS OF VG224
duplex auto
speed auto
h323-gateway voip bind srcaddr 192.168.10.10 //IP ADDRESS OF VG224
dial-peer voice 1000 voip
description outgoing calls TO ROUTER
destination-pattern 0T
session target ipv4:192.168.10.1 //IP ADDRESS OF 2961 ROUTER
voice-class h323 1
codec g711alaw
no vad
fax protocol none
dial-peer voice 1001 voip
description outgoing calls From 2961 ROUTER
voice-class h323 1
codec g711alaw
no vad
fax protocol none
dial-peer voice 10 pots
description incoming calls to a port on the VG224
destination-pattern 3000
port 0/0
forward-digits all
ā11-21-2014 02:28 PM
Valincia,
first of all you need to make a protocol strategy for this network and i prefer it be like this:-
1- add the 2 VGs works as sccp gateway with the CUCM.
2- add the 2 IP-phones as sccp client with the CUCM.
3- add the 2961 router GW as MGCP with the CUCM. ( you didn't mention CUCM version so be aware of the router if its supported as MGCP router inside the CUCM )
after doing that you could do what you need from call routing inside call manager.
Saif Musa
ā11-23-2014 03:06 PM
We are using CUCM 8.6. We would prefer to add the 2961 as a h323. Because most of our sites use H323.
