11-21-2014 05:11 AM - edited 03-14-2019 02:07 PM
I am getting below error while login on Cisco Finesse. and this is happening only for Cisco 7941 phones
Error - " The device associated with that extension or dial number is invalid."
I already tried troubleshooting steps mentioned in the below discussion
https://supportforums.cisco.com/discussion/12149211/finesse-91-sign-error
CM version - 9.1.2
UCCE - 9.0.4
11-23-2014 07:44 PM
Can you verify if this was working before? have you tried restarting the Cisco Tomcat service from the Finesse server?
11-24-2014 12:48 AM
We recently upgraded CUCM and UCCE to latest version. Agents are able to login with other phones except few Cisco 7941.
11-29-2014 08:41 PM
Ensure the mac is associated to the RMCM Application User
12-03-2014 05:23 AM
Other phones are working fine and this is happening only with 7941 phones ( few 7941 phones are working) I already removed phone from RMCM application user and added again - but no luck
12-04-2014 04:11 AM
Desktop-webservices logs from finesse server
Note - we are facing this issue with 79XX phones ( some 79xx phones works fine with out any issues)
Login ID - 7101
0034249002: 10.1.101.10: Dec 04 2014 06:46:10.304 -0500: %CCBU_pool-5-thread-157-3-CMD_FAILED: %[ENTITY_ID=7101][ERROR_DESCRIPTION=errorCode 70][command_name=LOGIN]: Received failed command response
0000334208: 10.1.101.10: Dec 04 2014 06:46:10.305 -0500: %CCBU_pool-5-thread-157-6-XMPP_PUBLISH_ASYNCHRONOUS: %[NodeId=/finesse/api/User/7101][Payload=<Update><data><apiErrors><apiError><errorData>70</errorData>
<errorMessage>CF_GENERIC_UNSPECIFIED_REJECTION</errorMessage><errorType>Invalid Device</errorType></apiError></apiErrors></data><event>put</event><requestId>fb29aff7-7071-4f75-a105-dc40eefd9eda</requestId><source>/finesse/api/User/7101</source></Update>]: Publishing XMPP Message Asynchronously
11-30-2014 08:09 AM
02-11-2020 01:51 PM
Could you fix this issue?, I have the same issue with and UCCE 11.6 and CUCM 11.5
02-12-2020 06:01 AM
7941 are not on the compatibility matrix for UCCE 11.6
02-12-2020 10:08 AM
in my case we are using 7945. Agents work with Extension Mobility.
If we change the DN on Device Profile, the agent can login to Finesse without problem, but if we change the old DN then the loging fails, here is the log on finesse locallogs desktop:
Container : [ClientServices] MasterPublisher._parseAndPublishXMLEvent() - Received XML event on node '/finesse/api/User/00001613': <Update>
<data>
<apiErrors>
<apiError>
<errorType>Generic Unable To Login</errorType>
</apiError>
</apiErrors>
</data>
I couldn´t find any information related to code "70".
