NEED HELP WITH ACE LOAD BALANCING POLICY PLEASE
raul saurez
I need create a policy that allows incoming connections between two servers I have configured for PLM. From what I noticed there is a jsession ID sticky predictor. Where do I configure the VIP? The policy process is confusing and I dont know where to begin. Here are my two server configs. can anyone help??
rserver host JAG-PLM9APP-02
  ip address 172.28.9.81
  inservice
rserver host JAG-PLM9WEB-02
  ip address 172.28.9.87
  inservice
serverfarm host PLM9-WEB-SF
  rserver JAG-PLM9APP-02
    inservice
  rserver JAG-PLM9WEB-02
    inservice
Something like this:
policy-map multi-match PM_MULTI_MATCH
  class VS_Classmap
    loadbalance vip inservice
    loadbalance policy Policy-MAP_LB
    loadbalance vip icmp-reply active
nat dynamic 1 vlan 18------>This statement and the one below
interface vlan 18
  description Client Vlan
  ip address 172.28.18.124 255.255.255.128
  service-policy input PM_MULTI_MATCH
  no shutdown
interface vlan 109
  description Servers Vlan
  ip address 1.1.1.1 255.255.255.128
nat-pool 1 1.1.1.2 1.1.1.3 netmask 255.255.255.0 pat---->And this one.
  no shutdown
This will ensure that client source IP is natted to 1.1.1.2 or 1.1.1.3 and the return traffic comes back to ACE.
Kanwal
Note: Please mark answers if they are helpful.
30 Replies 30
Kanwaljeet Singh
Here's the simple LB config:
login timeout 0
access-list ANYONE line 10 extended permit ip any any
probe tcp TCP
rserver host SERVER_01
  ip address 192.168.1.11
  inservice
rserver host SERVER_02
  ip address 192.168.1.12
  inservice
rserver host SERVER_03
  ip address 192.168.1.13
  inservice
serverfarm host REAL_SERVERS
  probe TCP
  rserver SERVER_01
    inservice
  rserver SERVER_02
    inservice
  rserver SERVER_03
    inservice
class-map match-all VIP-30
  2 match virtual-address 172.16.51.30 tcp eq www----->This is how you define VIP.
policy-map type loadbalance first-match SLB_LOGIC--->Create a policy, class and associate SF.
  class class-default
    serverfarm REAL_SERVERS
policy-map multi-match CLIENT_VIPS---->This is L4 policy where you call the class map you defined
  class VIP-30
    loadbalance policy SLB_LOGIC---->This is the policy you defined above.
interface vlan 251
  description Client vlan
  ip address 172.16.51.11 255.255.255.0
  access-group input ANYONE
  service-policy input REMOTE_MGT
  service-policy input CLIENT_VIPS----->L4 policy should be associated with interface.
  no shutdown
interface vlan 451
  description Servers vlan
  no shutdown
ip route 0.0.0.0 0.0.0.0 172.16.51.1
Let me know if you have any questions.
Kanwal
Ok great this is what I have so far. Where do I get the IP's from for VIP and the VLAN's ? do I pull from my company IP scheme? Also when I am complete what is the best way to test that loadbalancing is taking place?
  inservice
  inservice
    inservice
    inservice
class-map match-all VS_Classmap
  2 match virtual-address 172.28.8.81 255.255.0.0 tcp any
policy-map type loadbalance first-match Policy-MAP_LB
  class class-default
    serverfarm PLM9-WEB-SF
  class VS_Classmap
interface vlan 400
interface vlan 401
Normally you should have 1 ip as VIP and not a complete subnet. Also, if your server's default GW is not ACE, you need to do source natting as well.
Otherwise the configuration looks fine.You can start by executing following commands:
Show serverfarm detail--->Ensure that servers show operational.
Show service-policy summary---->Ensure than VIP is IN-SRVC.
After this you can send the traffic from client to VIP and execute "show conn" to see to which server the request was forwarded. Use multiple clients and you should see traffic getting forwarded to both the real servers.
Kanwal
Yes but do I make up any IP address for the VIP or do I pull an address from my Company IP scope? For example the IP that I have in place now I completely made up myself off the top of my head. Would that work since it is virtual? I am trying to ping the VIP 172.28.8.81 but am receiving no response? do I need to change the IP? if so to what? BTW you have been a HUGE help and I thank you!!!
It depends upon you:) Yes, VIP can be any IP , but you would need proper routing on peripheral devices so that traffic destined for the VIP reaches it.
Kanwal
I see. Ok another question. In your opinion would it be best to choose round robin predictor or least conn?
It again depends upon your choice or deployment requirement. Least conn predictor would send the traffic to server serving least amount of connections where as round-robin will not care about it and send the traffic to the server in round-robin manner.
Kanwal
I am able to ping the VIP 172.28.18.81 but when I try to show connections I get nothing. What am I doing wrong that I am not able to create traffic so I may check if loadbalancing is taking place? here is my config
bri-200n-ace1/PLM9-TEST# sho run
Generating configuration....
  inservice
  inservice
    inservice
    inservice
class-map type management match-any PM_MULTI_MATCH
  201 match protocol snmp any
  202 match protocol http any
  203 match protocol https any
  204 match protocol icmp any
  205 match protocol ssh any
  206 match protocol telnet any
  207 match protocol xml-https any
  2 match virtual-address 172.28.18.81 tcp any
  class class-default
  class VS_Classmap
interface vlan 18
  no shutdown
interface vlan 109
  no shutdown
ip route 0.0.0.0 0.0.0.0 172.28.18.1
snmp-server contact "ANM"
snmp-server location "ANM"
snmp-server trap-source vlan 18
bri-200n-ace1/PLM9-TEST# ^C
bri-200n-ace1/PLM9-TEST# sho conn
total current connections : 0
conn-id    np dir proto vlan source                destination           state
Your servers are in subnet : 172.28.9.81/X, i assume they are not local to the ACE.  When the server reply, the traffic should come back to LB. I would suggest doing source NAT for the same.
Kanwal
I cant telnet to the VIP. it fails. it shows failures on each server and 10 dropped conns...what am I doing wrong?
What is the best way to configure that? do you have a sample config?
  class VS_Classmap
interface vlan 18
  no shutdown
interface vlan 109
  no shutdown
Kanwal
You are awesome! Thank you so much for all of your help!!!
Hello Kanwal,
I am trying to access http://172.28.18.81/tc/webclient  (VIP)  but I cant. I am not getting any response. My config looks correct so I don't know what I am missing. Can you take a look and see if you notice anything I meet be missing in order to get this to load balance and be able to access via browser? Thank you!!
probe icmp PING-PROBE
  interval 10
  faildetect 2
  passdetect interval 30
  passdetect count 2
  receive 4
probe http PLM9-HTTP-PROBE-7010
  port 7010
  interval 10
  faildetect 2
  passdetect interval 15
  passdetect count 2
  request method get url /HealthMonitor/probe.jsp
  expect status 200 200
  open 1
probe http PLM9-HTTP-PROBE-7011
  port 7011
  interval 10
  faildetect 2
  passdetect count 2
  open 1
  inservice
  inservice
  inservice
  predictor leastconns
    probe PLM9-HTTP-PROBE-7010
    fail-on-all
    inservice
    probe PLM9-HTTP-PROBE-7011
    fail-on-all
    inservice
  202 match protocol xml-https any
  203 match protocol telnet any
  204 match protocol ssh any
  205 match protocol icmp any
  206 match protocol https any
  207 match protocol http any
policy-map type management first-match management
  class PM_MULTI_MATCH
    permit
  class class-default
  class VS_Classmap
interface vlan 18
  no shutdown
interface vlan 109
  no shutdown
