12-01-2014 11:28 AM - edited 07-05-2021 02:02 AM
In WLC, how do I setup so that AccessPoint-1 (3602i) accepts connection from deviceA and deviceB only, but not deviceC ?
Note that other access points, such as AccessPoint-2 still takes connection from deviceA, B and C
I am using WLC v8.0
Please advise!
Solved! Go to Solution.
12-01-2014 01:59 PM
If I create a local policy and apply it on a WLAN, it blocks that MAC address on every AP. Not just 1 AP.
Local Policy is done on a per-SSID method. So this means if you want another AP not to block, then you create a separate SSID and assign different APs in an AP Group.
12-01-2014 01:21 PM
What kind of "connection" are you talking about? Are you talking about device based on MAC address? If this is the case, then go to Security > Local Policy and create a policy based on MAC address of a device. Then you apply the policy by going to your SSID and Policy Mapping tab.
12-01-2014 01:43 PM
Thank you Leo for answering my question. Yes. I was talking about device based on MAC address. If I create a local policy and apply it on a WLAN, it blocks that MAC address on every AP. Not just 1 AP.
Please advise further.
12-01-2014 01:59 PM
