ISE DashBoard Access issue
Mohsin Yasin
I am running distributed deployment with mutiple PSNs,MONs & Admin Nodes are deployed.I was verifying crtical vlan access and radius server dead critera and a test case scenrios to reboot/power off the devices for sometime and trun them on back and verify the service. But after devices came up i lost dashboard access There is no more GUI access though I am still able to access all the devices through CLI.
Could you please help me to identify the issue.
follwoing output for the referance.
isea001/admin# show application status ise
ISE Database listener is running, PID: 4947
ISE Database is running, number of processes: 29
ISE Application Server process is not running.
ISE Profiler DB is running, PID: 6173
ISE M&T Session Database is not running.
ISE M&T Log Collector is not running.
ISE M&T Log Processor is not running.
isem001/admin# show application status ise
ISE Database listener is running, PID: 4952
ISE Database is running, number of processes: 23
ISE Profiler DB is running, PID: 6131
ISE M&T Session Database is running, PID: 4646
ISE M&T Log Collector is running, PID: 6625
isep001/admin# show application status ise
ISE Database listener is running, PID: 4955
ISE Profiler DB is running, PID: 6215
isep002/admin# show application status ise
ISE Database listener is running, PID: 4953
ISE Profiler DB is running, PID: 6171
Thank you for taking the time to come back and sharing the solution to the problem! (+5 from me). If you happen to have the bug ID please share that as well!
Also, if your issue is resolved, you should mark the thread as "answered" :)
10 Replies 10
fogemarttt
You have a lot of services which are not running and that is not good.
You can try to restart these services manually on each node and see the error and push it here on the site. For the moment I suggest you to shut all the monitoring node and psn and to just restart one of each after restarting admin node.
Let us know,
Thanks fogemarttt    .
I was able to resolve the issue it was timzone synchronization issue due to a known Bug which is diagnosed by cisco TAC I changed the timezone reset the config to default and restored them back from repository and it started working.
nspasov
As long as this service "ISE Application Server process is not running." is not running, your GUI won't work. As it was already suggested, you can try restarting the ISE application or reload the node itself.
Thank you for rating helpful posts!
yes correct Neno
Mohsin Yasin
Hi Moshin, do you happen to have the BUG ID?
Hi Neno, the BuG ID # CSCuo68012
Thanks Moshin! (+5 from me!)
ajc
Level 7
Level 7
What version are you running on the ISE's?
Could you please post the path to the timezone and what value was suggested by Cisco?
