Prime Infrastructure AAA with ISE
grabonlee
Level 4
Level 4
I have configured Authc and Authz policies as follows:
Authc:
If Radius-NAS-Port-Type EQUALS Virtual the Default Network Access and use AD
Authz:
   AND AD Specific User Group
   then Authz Profile Permissions (Cisco av-pair = NCS:role0=Root and NCS:virtual-domain0=ROOT-DOMAIN)
I am able to authenticate successfully and the Authorisation permission is applied and I can see this from the Authentication logs, but after that it seems ISE goes back to the Default Authentication policy of Deny Access.
Please could any one explain why this failure as the Prime Admin guide doesn't have the proper configuration steps.
Seth Bjorn
For my authorization profile result in ISE for PI, I use the following:
Access Type = ACCESS_ACCEPT
cisco-av-pair = NCS:virtual-domain0=ROOT-DOMAIN
cisco-av-pair = NCS:role0=Root
Now you would obviously need to change this if you have multiple virtual domains in PI. It looks similar to what you are using.
My successful login is shown below (however I don't see the Virtual port type):
Source Timestamp2015-03-03 10:23:56.123
Received Timestamp2015-03-03 10:23:56.123
Policy ServerMYISESERVER
Event5200 Authentication succeeded
Failure Reason
Resolution
Root cause
Usernamemycoolusername
User Type
Endpoint Id
Endpoint Profile
IP Address
Identity StoreMYADIDENTITYSTORE
Identity Group
Audit Session Id
Authentication MethodPAP_ASCII
Authentication ProtocolPAP_ASCII
Service Type
Network DevicePISERVERNAME
Device TypeNetwork Management
LocationCorporate Office
NAS IP AddressPI-IP-ADDRESS
NAS Port Id
NAS Port Type
Authorization ProfileCisco-Prime-Infrastructure
Posture StatusNotApplicable
Security Group
Response Time19
Try taking out the port type=virtual in your authorization profile config. I only see the port type=virtual in the authentication.
10 Replies 10
nspasov
Are you saying that you are initially able to login as an administrator to Prime but then any subsequent authentications fail?
No. What I am saying is that I successfully authenticate and the authorisation policy+profile above is applied. But this fails despite the fact it's just a Cisco-av-pair as shown above.
I can see from Operations > Authentication that Authentication is successful and Auth profile applied.
After this, I see fail and when I check the details, the message is Authentication > Default policy, subject not found in ID store.
I am not sure I fully understand exact flow and the problem. Can you post screenshots of the following:
1. Prime radius and AAA configurations
2. ISE Policy Configuration
3. Authentication screen of the failed/pass authentication
Please see attached
I should've updated long ago. Removed the NAS-Port-Type=Virtual and replaced with NDG  created for Prime i.e Device:DeviceType=Prime.
For Authentication, the I left the Radius=Virtual in the Policy
ALAN MURRAY
Does anybody have a solution to this issue? I am having the same problem - it's as though a second request is sent to ISE which only matches up to the Default policy which, in my case, is deny access.
Seth Bjorn
Failure Reason
Resolution
Root cause
User Type
Endpoint Id
Endpoint Profile
IP Address
Identity Group
Audit Session Id
Service Type
NAS Port Id
NAS Port Type
Security Group
Response Time19
Thanks, Seth. I'll try that.
Taking out the port-type=virtual in the authorization profile sorted things out for Alan and I. Thanks for taking the time to answer, Seth.
(We're still using role0=Admin, though, as appropriate for the permissions setup we're using)
Marco Aresu
i am expecting the same problem.
Where i will remove port type=virtual?
In my authorization profile i have :
Marco
