12-09-2014 08:12 AM - edited 03-07-2019 09:49 PM
I have two 6500 series switches; a 6506 and a 6509. Can I run VSS between these two different hardware models?
12-09-2014 08:28 AM
Yes, you can mix different models, as long as the sups are the same.
BTW, they need to be E chassis.
12-09-2014 08:49 AM
Not sure if the chassis are both E.....I don't think so...
show ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXI8, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Sat 22-Oct-11 01:53 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
uptime is 3 years, 3 weeks, 3 days, 19 hours, 17 minutes
Uptime for this control processor is 3 years, 3 weeks, 3 days, 17 hours, 52 minutes
Time since switched to active is 3 years, 3 weeks, 3 days, 18 hours, 6 minutes
System returned to ROM by power cycle (SP by power on)
System restarted at 17:37:45 EST Tue Nov 15 2011
System image file is "disk0:s72033-advipservicesk9_wan-mz.122-33.SXI8.bin"
Last reload reason: power-on
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.5) with 458720K/65536K bytes of memory.
Processor board ID SMG1422N01J
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
1 SSC-400 controller (1 IPSEC).
19 Virtual Ethernet interfaces
48 FastEthernet interfaces
60 Gigabit Ethernet interfaces
32 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
show ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISE_WAN-M), Version 12.2(33)SXI8, RELEASE SOFTWARE (fc2)
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
uptime is 1 year, 25 weeks, 5 days, 17 hours, 50 minutes
Uptime for this control processor is 1 year, 25 weeks, 5 days, 17 hours, 41 minutes
Time since switched to active is 1 year, 25 weeks, 5 days, 17 hours, 47 minutes
System returned to ROM by reload at 02:33:27 UTC Sat Mar 25 2000 (SP by reload)
System restarted at 22:58:49 UTC Tue Jun 11 2013
System image file is "sup-bootdisk:s72033-adventerprise_wan-mz.122-33.SXI8.bin"
Last reload reason: reload
cisco WS-C6506 (R7000) processor (revision 3.0) with 458720K/65536K bytes of memory.
Processor board ID SAL0803SXWD
Last reset from s/w reset
7 Virtual Ethernet interfaces
50 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
12-09-2014 08:53 AM
Yes, they are:
WS-C6509-E
12-09-2014 08:59 AM
I dont see where the 6506 is an E chassis . The 6509 is a E chassis .
12-09-2014 09:03 AM
My apologies Glen and Arthur. Only 6509 is E.
Reza
12-09-2014 10:25 AM
According the documentation i've found on the Cisco site...they don't have to be both be E-Series Chassis. See the second bullet.
4. VSS utilizes existing multilayer switching architecture.
• VSS enhances existing multilayer switching architecture using simplification of architecture without fundamentally changing the architecture resulting in easy of adoption of the technology.
• Uses existing Cisco Catalyst 6500 investments, easing the deployment of VSS. The VSS is supported on non-E and E series Catalyst 6500 Series Switches chassis and supports all Cisco Catalyst 6500 series 6700 series modules.
• VSS uses standards-based 10 Gigabit Ethernet connectivity between the Cisco Catalyst 6500 virtual switch members, allowing for flexible distance options. The underlying physical switches do not have to be collocated.
Source - http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-virtual-switching-system-1440/prod_qas0900aecd806ed74b.html
