12-11-2014 07:22 PM - edited 03-17-2019 01:18 AM
Analog phone->PABX1->VG1->WAN->VG2-CUCM2->Cisco 7821 phone ->transfer to another Cisco phone in same CUCM.
PABX1 - 3rd party telephony system in Site 1 (Aastra, ex-Ericsson MD110)
VG1 - old Cisco voice gateway router running as H323 gateway in Site 1(E1 to IP)
WAN - IPVPN link between PABX1 & VG1 in site 1 to CUCM2 &VG2 in site 2
CUCM2 - CUCM 10.5 controlling VG2 via H323(Site 2)
VG2 - Cisco 2901 ISR
Hi all,
I have deployed CUCM 10.5 with 3 phone models, Cisco 7821, Cisco 8945 and DX 650. All are running SIP protocols.
As per scenario above, when the Cisco 7821 try to transfer the call from the analog phone to another cisco 7821/8945/DX 650 phone, the transfer will fail. From my observation as soon as the call is put on hold, the call is going to be disconnected once you try to resume. I have tried upgrading to the latest firmware sip78xx.10-2-1-12SR1-4 also not able to resolve the issue. However, if call is just between the analog phone and Cisco 7821 there is no problem in conversation.
If the call transfer is internal within the CUCM 10.5 , there is no issue with the 7821. Only when the call is coming from the 3rd party PABX and need to transfer, it fails. However, for Cisco 8945 and DX 650, they have no problem transferring call from the 3rd party PABX.
So, I am wondering if this a compatibility issue for the Cisco 7821 phone.
Also to add, there is also no issue on transfer using Jabber mobile on phone.
12-12-2014 07:04 AM
is VG1 registered on CUCM.
what is the protocol used for VG1 and VG2 ?
Anas
12-15-2014 12:03 AM
VG1 is used as a H323 gateway and link to the 3rd part PABX via E1. VG2 is used as a H323 gateway as well.
04-27-2015 08:53 AM
I have a similar issue:
3rdparty IPphone->3rd party PBX->WAN->CME->cisco 7821
Calls between 7821 are OK including transfers.
When 3rd party phone calls 7821, the call is OK. But if you transfer the call to 7821, the transfer is successful but silent on both ends.
When 7821 calls 3rd party phone, call is OK and can even transfer to another 3rd party phone
When 7821 calls 3rd party phone, 3rd party phone can transfer to another 7821.
I have included all the necessary codecs. Anyone with an idea what could be happening?
