CIAC 4.1 installation - not able to deploy "SC_Services_4-1.xml" package
Dec 12th, 2014
I'm doing a fresh installation of CIAC 4.1, installed CPSC and also finished importing/deploying portal pages and done with Rex Adapter installation.
While deploying service package 'SC_Services_4-1.xml', it's just not finishing the deployment in spite of waiting for hours together. It seems to be quite a huge package at 56 MB, and we did have had difficulty deploying even 2 MB xml files in the previous 10.0 version.
We increased the heap size to see if that helps to 1 GB but it didn't help.
Appreciate your input on how to address this problem. Without resolving this, we cannot proceed with CIAC installation/configuration. Thank you
Song Bac Toh Tue, 12/16/2014 - 09:12
  • Cisco Employee,
It is best to file a TAC SR for such an issue.  Also, I suggest that you post this to the IAC forum.
Raghu Rachuri Tue, 12/16/2014 - 21:25
Thank you Song for your response. I just posted it in the IAC forum, just thought the issue is with the Catalog Deployer and hence posted here to see if anyone has faced the problem.
