Guest enrollment (self-service) on WLC 5508
Bernard Lara
Hi folks,
My desired setup is to integrate wlc 5508 (guest anchor) into cisco ise or nac server for guest authentication.
And then, ise or nac will connect to an SMS gateway to deliver credentials to mobile phones.
But I am looking into something unique where guests that enter into our facility can do self-enrollment. (i.e. guest connects to ssid and redirected to web authentication that asks for user information like name, email, mobile, etc).
After this process, guest will receive an sms for the credentials.
Does anyone here know a reliable third party software for the said enrolment that will work fine with my setup.
Your response are highly appreciated.
Moin Ilyas
Level 4
Level 4
http://www.cisco.com/c/en/us/support/docs/security/identity-services-engine/118742-configure-ise-00.html#anc17
Saurav Lodh
Level 7
Level 7
SMS notifications are not supported for self-registration, only for sponsor created guest accounts. Support with self service is in roadmap
Hi Saurav,
Now it is supported on 1.3
http://www.cisco.com/c/en/us/td/docs/security/ise/1-3/upgrade_guide/b_ise_upgrade_guide_13/b_ise_upgrade_guide_13_chapter_0101.html
Thank you Saurav
Moin Ilyas
Level 4
Level 4
