12-15-2014 05:46 AM - edited 03-18-2019 03:47 AM
I've got a VCS-C & VCS-E configured for UC Traversal. As part of this, I've enabled XMPP federation. Attempts to start a chat session with external contacts fail. In the VCS-E logs I see:
XCP_CM2[15061]: Level="1" Subject="cm-2.dev-vcs-e-example-com" Event="Identity Verification failure during either Server Dialback or Certificate Validation" Module="XMPPFederation"
I'm guessing something doesn't like the cm-2.dev-vcs-e-example-com name as it doesn't match the SN or SAN in the certificate for the VCS-E. Firstly, the host is dev-vcs-e.example.com Secondly, I have no idea what "cm-2" is. It's certainly not the name of any host on my system (Either CUCM or IM&P)
Any suggestions or pointers on what to do to fix this?
GTG
12-16-2014 01:29 AM
Please always mention which software versions you use.
It this string the exact one you see or did you modify parts of it to show it to us?
Did you check your or the remote certificates and hosts if this is name is configured somewhere?
Some docs:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/im_presence/interdomain_federation/10_5_1/CUP0_BK_I07B7052_00_integration-guide-interdomain-federation-105/CUP0_BK_I07B7052_00_integration-guide-interdomain-federation-105_chapter_01010.html
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/X8-1/Cisco-VCS-Certificate-Creation-and-Use-Deployment-Guide-X8-1.pdf
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/expressway/config_guide/X8-1/Cisco-Expressway-Certificate-Creation-and-Use-Deployment-Guide-X8-1.pdf
12-16-2014 07:49 AM
Sorry, it's VCS V8.2.2
I just changed the domain name to example.com.
I didn't check the remote certificate. I couldn't see the point as most of the SAN was my domain. I haven't seen anywhere in CUPSAdmin where the name cm-2 is set (Hence my post!)
GTG
12-16-2014 09:12 AM
At least cm-2 sounds like communications manager 2 to me ;-)
12-16-2014 12:11 PM
Pity one of the servers is actually called cucmdev-2 ;-)
GTG
10-09-2015 01:06 PM
Any luck with this Gordon?
10-10-2015 10:47 AM
Mathew.
This error points to a DNS problem on the receiving side. You should have them check that they can resolve your federation domain
10-15-2015 05:48 AM
I'm struggling to remember the details. Either the VCS cert was missing a SAN, or there was an error in my SRV records.
Sorry,
GTG
