12-22-2014 05:57 PM
Could I configure local switching between sub-interface and global interface on ASR9k?
12-22-2014 11:32 PM
I'm guessing you are talking about two different interfaces, for example:
g0/0/0/0.123 (subinterface)
and
g0/3/0/0 (global interface)
If this is the case, yes. You just put both interfaces on a bridge domain / bridge group and they will be able to switch packets locally. Pay attention to the packet tagging (the subinterface might be receiving tagged packets, so you will have to pop the tag at arrival).
More info:
http://www.cisco.com/c/en/us/support/docs/routers/asr-9000-series-aggregation-services-routers/116500-problemsolution-product-00.html
12-25-2014 05:40 AM
For 2 interfaces it is probably best to use an xconnect. It is faster and saves system resources (eg mac learning doesnt apply to xconnect).
Config example:
l2vpn
xconnect group link
p2p link
interface Bundle-Ether100.4321
interface Bundle-Ether500.4321
EFP config:
interface Bundle-Ether100.4321 l2transport
encapsulation dot1q 4000
rewrite ingress tag pop 1 symmetric
interface Bundle-Ether500.4321 l2transport
encapsulation dot1q 2000
This example shows that you can link 2 EFP's with different vlan's together if you'd pop the tags.
If the EFP's are of the same vlan, then popping the tag can be done but not a must. In general it is recommended to always pop vlan tags so there is a standard EFP design, but not for any technical reasons.
When you use a bridge domain and using a BVI, you MUST pop the tags as the BVI has no notion of a vlan tag and wants to see "plain ethernet".
regards
xander
