Warning message
DefaultL2LGroup keeps trying to connect to an old IP address
Answered Question
Dec 28th, 2014
Hello all,
We have a Cisco ASA 5510 that had a VPN tunnel established with the previous network administrator's home connection.  When he resigned, we deleted the tunnel-group.  I've noticed, however, in the logs we still see:
4Dec 28 201407:51:26     Group = DefaultL2LGroup, IP = x.x.x.x, ERROR, had problems decrypting packet, probably due to mismatched pre-shared key. Aborting
Where the x.x.x.x is the guy's home IP address. I tried grepping his IP in show run and all I found were an acl entry.  Is there any way to get DefaultL2LGroup to stop trying to reestablish this tunnel?
Thanks!
Correct Answer by Marvin Rhoads about 2 years 7 months ago
Since you see
I would say his configuration is still trying to send you encrypted packets.
Overall Rating: 5 (1 ratings)
johnlloyd_13 Sun, 12/28/2014 - 18:53
  • Blue, 1500 points or more
hi,
you'll need to remove the crypto related config.
no crypto isakmp key <KEY> address <PREV ADMIN'S IP>
no crypto ipsec transform-set <TSET NAME>
no crypto map <CMAP NAME> <SEQUENCE NUM>
Marvin Rhoads Sun, 12/28/2014 - 19:10
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
If he still has the L2L VPN setup at his end, the only thing you can do is to filter his address, preferably on the upstream router - if that's under your control - or have him remove his end's config.
tedbronson Sun, 12/28/2014 - 22:12
He says he has removed it on his end, and that our firewall is still trying to bring up a tunnel with him.
When I do "no crypto isakmp key <key> address <ip> I get:
ERROR:no keyword not supported.Command deprecated
Usage: crypto { ca | dynamic-map | engine | ipsec | isakmp | key | map  }
        For more detailed help, please refer directly to the subcommands
If I understand everything right we are using the transform-set for other VPN connections as well.
For the last one, I don't see any crypto map entries with his IP as the peer.
Correct Answer
Marvin Rhoads Mon, 12/29/2014 - 05:47
  • Hall of Fame,
Since you see
tedbronson Mon, 12/29/2014 - 11:41
That was the problem, he thought he had removed it from his end and hadn't. Thanks!
