SG 300-28P changes to excluded
Chris Hein
I have a SG300-28P that when I plug in a Avaya VOIP phone, changes from tagged to excluded on my VLAN 50 that I have set aside for phones.  The phone that doesn't work until I change it back to tagged.  Then if you reboot the phone, it doesn't change it back again and stays working.  How can I prevent having to do this every time I connect a new phone to my switch?
Hi Chris, depending on the phone model it may not support the CDP message from the auto-voice VLAN assignment. In some phone deployments, it may be best suited to use the LLDP-MED to consistently feed the telephone VLAN tag.
Assuming your phone supports LLDP-MED, set up the policy and apply it. If this also does not work then your next option would be telephony OUI where you'd register the phone MAC address to assign the VLAN tag based off that MAC registration.
Here's a document to help with LLDP-MED
https://supportforums.cisco.com/document/112876/how-configure-lldp-med-sx300
Here's another document to configure the Telephony OUI
https://supportforums.cisco.com/document/112881/how-configure-telephony-oui-sx300
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
7 Replies 7
mpyhala
Level 7
Level 7
Chris,
Under VLAN Management-> Voice VLAN-> Auto Voice VLAN, is the Voice VLAN ID: set to 50?
- Marty
Yes, it is set to 50.
Hi Chris,
what is your running config (in particularly for the affected port) and mac address table for this problematic port?
Aleksandra
It affects all ports.
Hi Chris,
can you share with us?
Aleksandra
What would you like to know?  I use the GUI, so I can't cut and paste.
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
