12-31-2014 08:09 AM - edited 03-11-2019 10:17 PM
my company bought a new asa cisco 5585 and asked me to implement the asa in order to secure the internet because.
This is because every time we have the internet speed problems because of the end users. So in order to secure and make the internet connection fast what are the steps i should configure in my asa as a security measures. Currently ISP has given the 14 MBPS speed connection to our company.
1] shall i block browsing the video sites or downloading the torrent?
2] Do i have to do anything with traffic policing and shaping?
Solved! Go to Solution.
12-31-2014 06:42 PM
Blocking of Torrent is common sense. You can do this via Active Directory. Blocking Torrent is ineffective, in some cases on the FW, because you'll need to block a large chunk of ports which can sometimes conflict with some applications.
Do a netflow to determine what traffic are passing through and block accordingly.
12-31-2014 10:40 PM
I would agree that we need to have a look at the traffic through the ASA device which is consuming the Bandwidth , after that you can use some option on the ASA device like the modules For Ex:- CX , IPS etc to block these applications if they are causing the problem with the Bandwidth.
Thanks and Regards,
Vibhor Amrodia
12-31-2014 06:42 PM
12-31-2014 10:40 PM
Thanks and Regards,
Vibhor Amrodia
