01-07-2015 07:38 AM
I am trying to upgrade the WSA through upgrade procedure on the gui.
I keep getting this error "Failure downloading upgrade list: Failed to authenticate with manifest server"
I have a temp license which is running currently as my permanent license is still not activated due to contract is not active. Is this with regards to license.
Please help...
01-07-2015 09:31 AM
Expired feature keys are usually the reason for this error message.
You can check if you have valid "temp license" on System Administration -> Feature keys. Are keys expired already?
Please also check that time & date are set correctly: System Administration -> Time Settings.
You can ask your Cisco Sales Rep to generate demo license for you that will give you 45 days to solve issues with your new contract.
The last but not the leaset: you're able to do system upgrade with valid demo license also.
01-07-2015 10:34 AM
I have a 30 days license with it and all of them are active. Execpt https is dormant all other are active
the date and time are also correct.
01-07-2015 11:52 AM
What does "showlicense" show?
01-28-2017 07:47 AM
Thats correct, this type of problem its because expired license. Typing en CLI showlicense probably see and expired license.
